on 11-11-2021 16:11
Hi gang ,
just installed tv360, paired my tv , when testing it activates the volume . When I click DONE , it no longer controls volume or mute. But does turn tv on and off. Annoying . Help please
on 11-11-2021 16:23
Did you try putting in the TV model number, if you are setting it by just pressing the volume key don't always accept the first one that works try some more.
on 11-11-2021 17:01
Yes I enter model number and all work. When I press done to close the setting it fails to store the setting .
on 12-11-2021 17:26
Welcome to my world. I am also a new v360 user with an LG TV.
You probably want to look at a post I made a few days ago. It contains a list of faults that I hit in a 6 week period, as well as a solution to all of them. Well, all bar the softish Sky Sports HD picture that seems to be a generic issue for most viewers.
I am sorry to say the workaroud is a hardware solution, designed to avoid the TV handshaking directly with the v360 box via its hdmi connection. But it does work and will probably save you a lot of future pain if you have only found the volume issue so far.
on 12-11-2021 17:39
This is the link /LG-TVs-and-Virgin-360-woes-a-solution-or-at-least-a-workaround/ @spedwards was referring to.
To insert a link click on the paperclip icon in the toolbar at the top of the post you are writing.
Then insert the link in the box that opens. You can edit how it appears in the post in the text to display box.
on 12-11-2021 17:43
I have an LG TV too which I have no problems with, however I've made a booboo a few times when checking how to set up the remote for other users who are having problems.
Under Settings > Audio & Video > Volume keys control ... make sure it's set to LG TV and NOT LG Amplifier.
on 12-11-2021 19:08
Good point. Each generation of LG Tv will have different firmware and interraction. As will each of the panel types. I shouldn't assume all will react like our OLED C8 did.
on 15-11-2021 09:00
Good morning @stevehathway.
Welcome back to the forums and thank you once again for taking the time to post.
Has the work around provide solved the issues you are currently experiencing?
Kind regards,
Zak_M
