on 05-10-2022 22:49
Hi after getting my tivo box upgraded to a 360 and the enginear linking my 360 remote to my jvc tv so i can use the volume since that has been done i can not turn my tv of with either remote or or use anyother button on my tv remote except the volume i now have to turn my tv of at the socket please help ive even tried reseting my 360 remote but it pairs straight back up to the tv when the virgin box is turned of my tv remote is fine
Answered! Go to Answer
on 08-10-2022 10:01
Hi @Rik1,
A warm welcome to our Community Forums and thanks for your post. It's great to have you on board with us here 🙂
I am sorry to hear you're having some issues with your Virgin 360 remote.
Did you press and hold the TV and Rewind button for 10 seconds to factory reset the TV 360 remote?
You can also pair the 360 remote by holding down the 'TV' button and '0' button together until the Standby button starts to flash.
Can you also check the power saving mode setting is on Fast Start?
In the interim period, you can also use the Virgin TV Go app to control your TV box. For more info see here
Give that a try and let us know if it makes any difference.
Cheers
on 08-10-2022 10:01
Hi @Rik1,
Cheers
on 08-10-2022 13:04
Like i said ive tried a reset it dosent work i think its the fact that they have upgraded my old tivo box rather than give me a new one
on 10-10-2022 14:25
It'll be how the remotes have been paired and programmed to the set top box.
Can you confirm which make and model your TV is and we'll try and investigate the issue further to find a resolution.
on 10-10-2022 15:12
Hi its a jvc tv is there anyway to just unpair it from the tv because when i reset the remote it automatically pairs back up to the tv
on 10-10-2022 15:16
model no LT-42C550
on 10-10-2022 15:46
Hi @Rik1
I hope the following helps.
Both remotes should be able to turn your TV on and off.
When pairing the 360 with your TV you can either search for device number LT42 or device number 42C5 both should work.
When the 360 says it's found a matching device and asks you to check that the volume keys are working you can select no and it will then search again. Sometimes there is more than one configuration that works, some better than others.
The red power button on the 360 remote should allow you to allow yuo to switch the 360 on and off, plus if yuo have enabled One Power in the 360 settings it should also you switch your TV on and off at the same time.
The black TV button on the left hand side of the 360 remote should allow you to switch your TV on and off independently of the 360 set top box.
On your 360 go into Settings > System> One power and set that to ON. - that allows it to control the TV On/Off function.
On your actual TV you need to set up HDMI - CEC - that should ensure that both remotes can turn your TV on and Off - see the screenshot below.
on 10-10-2022 15:56
Great thanks i will try that as soon as i get home
on 10-10-2022 20:48
Great thanks everything is working spot on now
on 10-10-2022 20:53
Hi again @Rik1
Thanks for the update, that's brilliant news.
Stay safe and take care.
