stuffyouguys
Tv 360 led on box
How do I make led brighter on the front of the rv 360 box? When I first converted it was bright enough to see, now it seems to have dimmed to almost invisible
Tags (1)
jb66
  • 12.43K
  • 925
  • 1.83K
Re: Tv 360 led on box
There are no LED brightness settings that can be changed on the box
stuffyouguys
I rebooted the box and Led is back to normal brightness.
martinianpaul
  • 139
  • 36
Up to speed
The blue/white LED has changed every time the software has been updated, in my experience r.  I use the eco mode and the led used to go off during standby.  Then it went blue. Now its back to off again.
stuffyouguys
Led light has gone out again. Seems to only work after a reboot but the as soon as you put the box in standby the led light on the front goes out. This seems to be a bug and would need to be looked at and fixed in an update perhaps... Anybody else having this issue
BenMcr
  • 21.91K
  • 2.39K
  • 4.46K
What's your Power Settings?
Go to Home > Settings > System > Standby power consumption
