on 11-08-2021 15:08
Just upgraded to Tv 360. With my old system it was easy to browse channels grouped under headings such as movies, sport etc. How do I do this with my new remote?
thanks in advance.
Steve
Answered! Go to Answer
on 11-08-2021 17:24
Sorted! Good old trial and error and no thanks to the VM manual. You hit the home button while in the guide to activate the filters.
thanks to those who made suggestions.
steve
on 11-08-2021 15:47
Go into the Guide and change the My Channels field to the grouping choice you want.
on 11-08-2021 16:36
Thanks for the reply. Not seeing a ‘my channels’ field. How do I access that?
Steve
on 11-08-2021 16:52
I think Ernie means the All Channels field at the top of the Guide.
on 11-08-2021 16:57
If you have a profile, you can get the field to default to My Channels.
on 11-08-2021 17:00
I can’t see any way of clicking on the all channels option. The up/down control just scrolls through the channel list. The guide provided by VM is pretty useless. I am probably being a bit thick but it was so easy with the old remote.
steve
on 11-08-2021 17:24
steve
