DJG01
TV GO no sound on saved Sky F1 channel
I have no sound on the Virgin TV GO app when watching a saved recording on SKy F1. All the other channels are fine. I’ve deleted.the app and reinstalled but still no good. I’m using a TV 360 box. Any ideas ?
Tags (1)
  • 13.96K
  • 1.87K
  • 4.29K
Re: TV GO no sound on saved Sky F1 channel
Hi @DJG01
Is the TVGO app on an ios device?
If so the following post should help /TV-on-the-go/No-sound-on-recordings-on-TVGO
Dave
