julie2g
TV Box not working red light
MY virgin  360 TV box stopped working had a red light on it then orange and wouldn't go beyond welcome page tried all suggestions and none worked  THEN I changed the batteries in the remote control and it worked straight away thought I'd post this to see if it helped anyone out who has the same problem.
David_Bn
  • 9.4K
  • 392
  • 715
Re: TV Box not working red light
Good Morning @julie2g, thanks for your post on our Community Forums, and a very warm welcome to you!
Sorry to hear of the issues you've been facing with the set top box.
This does sound like it's possibly a fault with the set top box you're experiencing.
How long has this issue been going on for?
Can you please confirm if all cabling running into the back of the set top box and into the wall socket are tight are secure?
Has a reboot using both the switch on the back of the set top box, and at the plug been performed?
Kindest regards,
David_Bn
julie2g
Hi David the remote control just needed a new set of batteries works perfectly now.
Zach_R
  • 4.89K
  • 159
  • 336
Hi @julie2g,
Thank you for the update on this. I'm glad to hear that your remote is now working again.
Please do let us know if there's anything more that we can assist you with.
Zach - Forum Team
