on 22-05-2022 19:15
Hello friends!
I’m having terrible synchronisation issues since receiving my Virgin TV 360 box about 6 weeks ago. I’ve read as many forums as I can, tried the fixes, to no avail.
Current setup is:
Connections are:
Sync issues:
Can anyone please help at all before I spend (lose) hours of my life calling technical support?
I’d sincerely appreciate your guidance and expertise to resolve this as quickly as possible.
Thank you!
on 31-05-2022 13:21
Can you also mention a few channels where you are having the issues, I am not seeing the Lipsync problem on my set up so am curious which channels you are having issues with so I can compare.
on 01-06-2022 20:42
Two Virgin Media engineers have been out this week and neither can figure out the problem so I don't think I'm going to find the answer through the forum this time. Thanks anyway. Go ahead and close this down.
on 01-06-2022 21:37
I know this isn't the ideal configuration but have you tried soundbar to TV using a non arc HDMI connector on the TV and then either the TV or 360 to the soundbar using optical.
on 01-06-2022 21:49
Yes, see original post on this thread. I've tried it all. And if 2 VM engineers can't resolve it after running tests and replacing the box then it's not an easy fix.
on 01-06-2022 22:04
If you decide to replace your soundbar get one with a HDMI-IN connector as well as the HDMI-ARC.
on 01-06-2022 22:24
Zero issues, ever, with the previous V6 software. Nothing at all.
So if the solution is to buy new equipment I'll expense it back to VM... 😉
on 01-06-2022 22:44
@dirtysparkles wrote:Zero issues, ever, with the previous V6 software. Nothing at all.
Good luck with that, the " it's third party equipment " quote I keep seeing springs to mind. What isn't third party equipment connected to 360. 🤔
