on 25-04-2023 19:49
Hi All,
I’ve just purchased a new Samsung TV and Soundbar. Everything works well and the picture and sound on BT Ultimate and Sky Sports UHD is fab, however we have noticed that the sound is slightly out of sync only on the BBC channels.
Does anyone know of a solution? I’ve changed the HDMI cables to newer better quality ones and the issue isn’t on the Apple TV we have or other VM channels only BBC 1,2 and News on VM?
on 25-04-2023 22:28
I'm no expert on VM but with Sky you could adjust sound delay. On my TV I can also match screen and sound BUT I'd have thought every channel would be put by same.
on 25-04-2023 22:38
Yeh that’s the issue, it’s only on BBC channels, I adjusted the delay on BBC but then knocked everything else out 😕
on 25-04-2023 23:12
I assume you have the 360 set to follow content for Dolby Digital or Atmos where available, does it make any difference to the sync problems on BBC if you set the audio to PCM 5.1 or 2.0.
How are we connected to the TV and soundbar, is it HDMI-ARC or 360 to soundbar then to the TV depending on the soundbar input's.
on 27-04-2023 20:13
So I've sorted it, but at the cost of Dolby Atmos on Sky and BT UHD.
I've plugged the Soundbar into the TV and instead of having the Virgin box go into the sound bar, I've also plugged it into the TV Directly. I've changed the Audio Output from Follow Contnent (recommended) to PCM 5.1 (HDMI Only). This has resolved the sound being out of sync on the BBC channels, but now stops Dolby Atmos from activating on BT Sport Ultimate and Sky Sports UHD which is very annoying.
I do like my soundbar, but it is the first one I've owned and I'm starting to think its more hassle than its worth.
on 28-04-2023 01:30
Hi Jacobtribe,
It's not easy sometimes to find all the settings, if your TV and soundbar are connected by HDMI-ARC and the 360 is connected to the TV the same as my LG TV and soundbar, you need something like Digital Sound Output set to Pass through with the 360 set to follow content for Dolby Atmos, I also have a HDMI Input Audio Format set to bitstream.
on 01-05-2023 12:12
Thanks for the advice, those settings that solved the sync issue but it still won't trigger atmos. I'll keep playing about with it see if I can get it on.
