Sound issues
Lovenbooze
Having issues with sound on Netflix and Disney+, sounds very jerky and robotic. Normal tv, recordings and prime all work fine. Don’t have any issue with these apps in another room using a fire stick.
1 ACCEPTED SOLUTION
Accepted Solutions
Hi @Lovenbooze
Have yuo tried the following?
For Sound issues go to Setting > Audio & Video > Audio Output > there are options > Follow Content, PCM 5.1 (HDMI only), and PCM 2.0
Choose whether you want the audio output to follow the quality of the original content (Dolby Digital where available) or to be converted to PCM 2.0 (stereo) or PCM 5.1 (uncompressed multi channel sound). Using PCM settings may resolve audio sync issues.
Netflix will always use Follow Content. Use 'Follow Content' for any bitstream audio like Atmos where it's available on content.
Dave
The do's and don'ts.
3 REPLIES 3
Hi @Lovenbooze
Dave
Thank you, ur amazing, been searching for weeks to sort that
Hi @Lovenbooze
Glad @newapollo was able to help get tings sorted and if you need anything else, don't hesitate to reach out 🙂
Have an amazing day!
Ayisha_B
