jackiethrussell
Sound cutting out every so often
I have an issue when watching virgin tv, every so often the sounds cuts out for a second or so - the picture is fine but keeps happening regularly - any suggestions to resolve this?
Thanks Jackie 🙏
Tags (1)
japitts
  • 12.04K
  • 1.67K
  • 2.58K
Re: Sound cutting out every so often
Is this on live TV, OnDemand, streaming, or recorded programmes? If live TV, are there any particular channel(s), including SD/HD? streaming - any particular apps?
How is your 360 connected for sound - HDMI to your TV, or optical to any soundbar or A/V kit?
jackiethrussell
I have my Samsung Frame TV connected via the Samsung One Box on a HDMI cable - nothing in between.
From what I remember it happens on live TV and recorded TV.
Any thoughts?
japitts
  • 12.04K
  • 1.67K
  • 2.58K
Are there any particular channel(s) this is happening on? SD or HD?
For elimination purposes, does the same happen if you toggle PCM/stereo using the audio settings menu? (Home > Help & Settings > Settings > Audio)
