robc2
Message 1 of 5
Solution for 4 boxes
Ive been getting conflicting information from Virgin.
I have a 360 main box and 2 mini boxes setup, but now need another room serviced.
The Virgin Site definitely says a max of 1nr 360 + 2 mini's however I thought I'd ask Virgin. Having done so I've been told 3 different things :-
1. Capped at 1nr main box + 2nr mini boxes as per the website
2. Yes you can have 1nr main box + 3nr mini boxes
3. As per 1. above but you can work around this by plumbing in another 360 main box
I'm not confident on any answer Ive been given as none of the people I spoke to seemed at all sure in what they were saying.
Any ideas which one it is? And if its nr3. how you would do that?
WoahWoahUser
  • 69
  • 7
Message 2 of 5
Re: Solution for 4 boxes
I think it’s only 1 main + 2 mini max and since you can’t keep tivo and 360 you’ll have to give up a box. You could find a way to split the signal on one of the boxes and send it to two tvs, but that’s a lot of effort and probably won’t work, due to HDCP.
stephentucker
  • 69
  • 26
Dialled in
Message 3 of 5
Hi, sorry cant give you an answer but may I ask what 'nr' means?
robc2
Message 4 of 5
nr means number
japitts
  • 10.56K
  • 1.48K
  • 2.13K
Message 5 of 5
Depends what you mean by splitting the signal.
Splitting the HDMI output from one STB, and send to two TVs - theoretically possible, but you only have one output and could introduce HDCP issues.
Splitting the coax feed - which I don't think is what's being suggested but is worth mentioning - is likely to end in mess or tears somehow.
I'm fairly sure that the 3 box limit on the V360 platform is currently firm, and this is one occasion where TiVo/Horizon differ (TiVo/V6 can currently have upto 4 boxes although normally only 3 can be V6).
