on 15-05-2023 19:02
I have screen corruption and stuttering sound on multiple Sky Movies (HD) channels - on both boxes - especially bad on rom com and thriller right now.
Anyone else getting the problem?
on 15-05-2023 19:55
Hi @speedski
Apart from checking all your cabling is snug and tight and free from kinks, have you used the /check-services/i function? You can also a run a test on your equipment from there.
If nothing is showing you could also try the Service Status number 0800 561 0061. This often gives details of more local issues down to postcode level.
on 15-05-2023 22:58
Do you have similar issues with Eurosport 2HD, More 4HD, Sky Documentatires HD or Quest HD?
on 16-05-2023 21:48
Yes, I have the same problem on all those channels 😞
on 16-05-2023 22:04
In that case, the standard advice for pixellation queries applies.
Pixellated pictures on live TV are often the sign of a signal fault. If you've rebooted your box once, then there's likely a fault somewhere, so this will need VM to intervene. You're likely to need either an engineer visit or a replacement box, depending on what VM's remote diagnostics turn up.
First check the automated faults line for any existing issues in your area that could be the cause: 0800 5610061. If nothing's reported, assume VM don't know about your fault and ideally you'll need to call them.
150 from a VM phone, 0345 4541111 from any other phone - choose the options for "I have a fault with my TV service". Alternatively you can wait on here for staff to respond, which may take a day or so
on 19-05-2023 09:57
Hello speedski
Sorry to hear of the issues regarding the picture quality on Sky Movies channels even in HD, we appreciate you making us aware and taking the time to raise this via the forums.
From checking there does appear to be an issue with one of your boxes, I will send you a Private Message to get some more details from you to arrange a technician.
Rob
