metalguru
  • 33
Message 1 of 13
Set 360 remote to work my Sony Soundbar but doesn't work anymore
It used to work but says it connects but when you get the green tick only the Tv is showing in the menu tbe amplifier is missing
roy247
  • 3.35K
  • 290
  • 782
Wise owl
Message 2 of 13
Re: Set 360 remote to work my Sony Soundbar but doesn't work anymore
Have you changed anything or has it just stopped working,
You can try doing a factory reset of the remote and repairing, instructions on this Page you need to scroll down, and then try pairing to your soundbar using the first 4 digits of the model number. You could try the manual button pressing just don't accept the first option.
If you have already tried this try a factory reset of the box, just select the option to keep your recordings, you will have to login to any apps again. Sometimes the remote and box stop being 100%.
metalguru
  • 33
Message 3 of 13
Re set the remote and the box. Still doesn't work.
metalguru
  • 33
Message 4 of 13
My downstairs box won't connect to the Internet either by ethernet anymore. It will by wifi but suddenly stopped on ethernet. I prefer ethernet to wifi. Is the box kaput?
  • 15.92K
  • 2.11K
  • 5K
Message 5 of 13
Hi @metalguru
Have you tried rebooting your hub as well?
Dave
Love, love and love, forever - Pele
metalguru
  • 33
Message 6 of 13
I have 2 V6 360 boxes the other one works fine when swapped over. But yeah have rebooted the hub numerous times
Vikki_M
  • 1.52K
  • 57
  • 106
Message 7 of 13
Hi @metalguru
Thank you for your post and welcome to our community.
I am sorry to hear you are having some issues with the TV box.
Are you getting any messages or error codes on screen?
If so, could you send us a picture please?
Please pop back to us when you can.
Vikki - Forum Team
metalguru
  • 33
Message 8 of 13
No error messages it says it will operate the soundbar after the volume changes then when you click ok it wont work and the amplifier option is missing. Also my other V6 360 won't work with ethernet. It's not a hub issue which it says it is as the other box works with ethernet.
Steven_L
  • 11.34K
  • 689
  • 1.15K
Message 9 of 13
Thanks for coming back to us @metalguru and I'm sorry for the ongoing issues with your TV boxes.
Are you able to connect your V6 360 via WiFi or can you connect via both methods?
Have you or are you able to try a different ethernet cable?
Regards,
Steven_L
metalguru
  • 33
Message 10 of 13
Have connected by wifi but the other box is too far away to connect. It's not the cable as I have loads and the other box works with the original cable anyway
