ajvega
  • 69
Message 1 of 7
Remote key LED's
I have my new 360 remotes, no issues so far but I was wondering If there was a way to keep the key LED's on longer than a second. It's a great feature but I like to watch TV with my lights off at night and especially still getting used to the remote it's quite annoying the LED's go off before you can look down to find a different button lol
AMD FX 8320E 8 core
Asus Crosshair IV Formula
8gb Corsair XMS3 DDR 3
Corsair 120gb SSD (Operating)
Nvidia Gforce GTX 960
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Message 2 of 7
Re: Remote key LED's
Hello
That is controlled by the hardware of remote and there is no way of changing that I am afraid.
Regards Mike
ajvega
  • 69
Message 3 of 7
Ah ok thanks
AMD FX 8320E 8 core
HydeTDS
Message 4 of 7
I've just subscribed to VM and find the limited illumination time a right royal pain! It might as well not be illuminated at all.
Can VM change this through a software update maybe? Do VM follow the questions\problems highlighted in these forums?
Cheers
Travis_M
  • 1.63K
  • 62
  • 132
Message 5 of 7
Hi @HydeTDS
Thanks for posting!
This isn't something I could change personally as this is the hardware of the remote but i'll feed this back to the team for possible further changes.
Regarda
Travis_M
HydeTDS
Message 6 of 7
Many thanks.
Travis_M
  • 1.63K
  • 62
  • 132
Message 7 of 7
You're very welcome. Have a great day.
Travis_M
