on 23-09-2022 15:28
23-09-2022 21:38 - edited 23-09-2022 21:40
Hi @RDJ16
The most recent Roku TV's have multiple HDMI ports and should work with VM's tivo, V6 and 360 set top boxes.
If you advise of the make and model number I will look and see if it appears in the settings on my 360
They should also work with all VM hubs as the new Roku TV's support built-in 802.11ac Wi-Fi. and also have a built in ethernet jack for wired connections.
Hi @RDJ16
on 24-09-2022 18:04
Thanks for the info. Really helpful, thank you so much
Cheers
