mcskimmpa
Radio schedule and can radio programs be recorded?
Is there a radio schedule and can radio programs be recorded? Available in old system.
roy247
  • 3.31K
  • 288
  • 776
Wise owl
Re: Radio schedule and can radio programs be recorded?
The radio channels you have on a V6 guide from 901 up are not on the 360, the radio side of things is based around apps so there is no schedule or programme listings and no way of recording.
japitts
  • 20.64K
  • 2.64K
  • 4.73K
Roy's given the answer, but by means of some general advice - I presume the "old" system you refer to is the TiVo-based V6 box, which is still very much current and supported albeit no longer available to new customers.
TiVo/V6 & 360 are very different systems with pros & cons both ways, but not all TiVo-functionality is currently replicated in 360 - and the ability to record radio channels is one of them.
BenMcr
  • 22.84K
  • 2.52K
  • 4.86K
And honestly if it was the other way around and the TiVo platform was being introduced now I doubt it would be any different. At some point you have to choose which bits of backwards compatibility you don't keep.
Radio as tunable channels predates TiVo on Virgin Media (and recordable boxes) as they were on the previous Digital TV boxes which again replicated the separate FM feeds that some cable franchises had in the analogue days.
mcskimmpa
Thank you for your reply, unfortunately the absence of radio recording was as I expected. It's a pity they have drop this, as I found recording radio series very useful.
mcskimmpa
Yes it was the V6. The Virgin Sales Guy told me 360 would be the same as the V6 service I had, but with many new features. Overall though the upgrade is an improvement.
