VMcustomer1234
Quick start help, previously on sky!
Hi there just got the virgin 360 package great stuff and the quick help is super easy EXCEPT I have no idea where the wall socket is which you need to connect everything to, all that comes from the walls is two wires that screw into the sky box! Can I used one of those wires or will a engineer need to be called out? Many thanks
nodrogd
  • 18.74K
  • 2.23K
  • 4.84K
Re: Quick start help, previously on sky!
Its likely when Sky was installed that their installer removed all Virgin wiring. Virgin is a competitior & many will deliberately do this.
Give VM a call & ask for a manned install. This should be free of charge.
VM BB TV Landline. Vonage 2nd line. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Customer since 1993
VMcustomer1234
Ah bugger thanks for your help, I believe installations are charged at £40? No helping it I suppose
Nathan_B
  • 5.04K
  • 170
  • 335
Hi there @VMcustomer1234, welcome to our forum and thanks for your post.
It does seem like we would need to arrange for the sockets to be re installed if they have been removed. I'll send you a PM to confirm your details to arrange this.
Nathan
