on 15-08-2021 16:23
Any one having problems watching watching recorded programmes?
An engineer has already visited and changed the box but still come up either code CS or the box is offline despite being connected through ethernet cable.
We have had nothing but issues since we got a wifi speed upgrade.
Hope someone can help? Wonder if it could be the HUB
on 15-08-2021 16:45
Are you watching on the same box as the programme was recorded? Or trying to stream between two boxes? The two scenarios would suggest different problems.
If the latter, are both boxes set to Fast Start/Active Start? You've mentioned CS codes, but not what the specific code(s) is/are...
on 15-08-2021 18:52
Yes I am trying to watch on the same box recorded.
The Cs code is number Cs2217.
I have done the diagnostic and all seems to be working as it should but it is the same codes that came up before they changed the box, could it be a new hub needed?
on 15-08-2021 18:58
If you're trying to watch on the same box as the recording is on, the Hub isn't involved.
Is this on all recordings or just particular ones?
You've not mentioned live TV issues so I'll assume that's good. Do you have any problems when you pause live TV and watch it delayed by perhaps 30 seconds?
Unfortunately Error code help for this code isn't very forthcoming.
on 15-08-2021 19:26
It is not all recorded programmes just some of them, includes programmes from gold, sky one and channel 5 to name just a few of those tried play back and pause seem fine, it's just frustrating same issue despite a replacement box and engineer visit.
on 15-08-2021 19:43
Might be worth checking new recordings, to see whether there may have been an historic issue, or if new ones are also affected. C5 & Sky One are available in SD & HD - are both affected?
Just to rule out another possibility - do you have a mini-box? I'm only asking because they don't have hard drives of their own, and any recordings you set on those, are actually recorded on the master box. All playback is then streamed.
on 15-08-2021 20:24
All programmes are playing on the mini box, the programmes that dont work on the main box all play on mini box.
They are SD & HD that wont play on the main box but same play on mini.
There is no difference is new or historic programmes on main box
on 17-08-2021 20:43
Hi @Whitesmith1975,
Welcome to our Community Forums and thanks for posting.
Checking the box stats, it's currently showing as unreachable. Can you please reboot the box so it's online and let us know so we can run through diagnostics this end?
on 18-08-2021 07:18
I am not at home until later on today, will let you know once it's done.
Or will ask my wife if she is in
on 18-08-2021 18:56
The box has been rebooted and is plugged in by ethernet cable
