Power supply doesn’t fit. Tv360 box.
sureshd
very annoying it’s so hard to speak to someone at Virgin Media
Trying to set up my TV360 box and have been given a power supply that doesn’t fit!
Please help!
1 ACCEPTED SOLUTION
Accepted Solutions
roy247
Community elder
You can either wait here for a member of the forum team to respond, usually takes 2-3 day's, or call 150 from your Virgin phone, mobile or landline, or 0345 454 1111 from any other phone which might be quicker.
When phoning choose the option to report a fault, then ignore all the options offered and you should then be placed into a queue to speak to someone.
2 REPLIES 2
roy247
Community elder
Reece_MH
Hi sureshd,
Thanks for your post, and a warm welcome to our Community Forums.
I'm sorry to hear you've received the wrong power adapter for your TV360 box. I've had a look on our side, and can't see any contact with our team regarding this, so I'm going to drop you a private message, so I can assist you with this.
Please look out for it in the top-right, purple envelope.
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
