steveqae
  • 55
Message 1 of 13
Power indicator light
Since upgrading my V6 box to 360 the power indicator light does not work. I have tried rebooting the box which did cure the problem but only for about 5 minutes. I now have no way telling if it is on or not.
roy247
  • 3.33K
  • 288
  • 777
Wise owl
Message 2 of 13
Re: Power indicator light
One thing to check is make sure the box is set to fast start or active start. Some users have had similar problems after an update and then the problem goes away after another update.
You could try a factory reset if you haven't already tried that, go to Settings > System > Factory Reset
It's only a partial system reset and not a complete factory reset. You are given 2 options,
Keep Recordings
Format Disk
Choose Keep Recordings, that means you won't lose your recordings and any planned recordings or series links you've set up, you will have to sign into your apps such as iPlayer, Prime, Netflix and ITVX again, also Match frame rate and Standby power consumption will go back to their default settings if you have changed them.
Matthew_ML
  • 3.59K
  • 132
  • 242
Message 3 of 13
Hey steveqae, thank you for reaching out and I am sorry to hear you are having some issues with the 360 box.
Did any of the above advice help at all or do you still need some help with this? Thanks
Matt - Forum Team
New around here?
steveqae
  • 55
Message 4 of 13
I have not yet had the chance to try it yet.
steveqae
  • 55
Message 5 of 13
OK I have done a factory reset, all is fine for now. Indicator light is back.
Thanks for the info.
Gareth_L
  • 11.5K
  • 635
  • 1.25K
Message 6 of 13
Hello steveqae,
Hope you are okay.
Just a quick message to see if the power indicator light has ben fixed yet?
Look forward to an update.
Gareth_L
steveqae
  • 55
Message 7 of 13
Yes,I did the reset as suggested and the indicator light is back, hope it stays that way.
steveqae
  • 55
Message 8 of 13
As I expected after the next use the indicator light has stopped working again.
steveqae
  • 55
Message 9 of 13
Any other suggestions?
Matthew_ML
  • 3.59K
  • 132
  • 242
Message 10 of 13
Hey steveqae, thank you for reaching out and letting us know this I am sorry to hear this has gone back to how it was.
I am going to send you a PM so we can look into this.
Please look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
