Caligulacabbage
  • 50
  • 11
Dialled in
Message 1 of 16
Okay first issue to report Battery Drain Voice Feature
Wow I have noticed that the four batteries reqd in the 360 remote drain quickly (yes I did replace them for branded ones ) when using Voice feature anyone else experiencing this or do I have either a) faulty remote or b) counterfeit batteries bought from my local supermarket ?????
Tags (2)
markdyer72
  • 284
  • 15
  • 62
Fibre optic
Message 2 of 16
Re: Okay first issue to report Battery Drain Voice Feature
I upgraded a week ago and I have the original batteries in and I use voice all the time and no problems with my remote as yet.
TiffanyGreen97
  • 368
  • 22
  • 98
Fibre optic
Message 3 of 16
I Upgraded 2 weeks ago using voice a lot still on the original batteries for both my remotes
martinianpaul
  • 140
  • 36
Up to speed
Message 4 of 16
Definitely one of the first things I reported.  After the set supplied with the remote died, I installed Duracell max batteries, which lasted about two weeks, maybe.  I don't often buy top of the range batteries but thought I would here.  But at this rate, I might try rechargeable ones!!!
martinianpaul
  • 140
  • 36
Up to speed
Message 5 of 16
Also, did you get an on-screen notification that the batteries needed replacing??  It's meant to be a feature of 4.28 but I've yet to see it.
Caligulacabbage
  • 50
  • 11
Dialled in
Message 6 of 16
No Battery message appeared on.the screen.
(360  version 4.28 OTA upgrade from V6 software)
Batteries replaced with Duracell let's see how long these last...more than two weeks I hope
Tags (2)
dave_herts
  • 12
Message 7 of 16
Mine died, just after a week of getting the remote, put it down to the remote probably been in storage for months!, got no warning on screen, just unable to do anything, enough power to control TV volume etc which confused matters somewhat. As a last resort, havinh rebooted box, before going through the trauma of phoning faults and getting we need to send someone out reply... decided to try putting new batteries in and voila it worked again, another drain is the remote lighting up when moved or buttons pressed.
WesthaMike
Message 8 of 16
No idea if it’s voice control or lights but mine have drained twice in a month so am now using rechargeable batteries.
this can’t be right
Ernie_C
  • 18.92K
  • 2.07K
  • 4.76K
Message 9 of 16
No, it can’t be right. I’ve had my TV 360 for four months now and the remote is going strong.
Suggest you request a new remote.
I’m not sure if this is currently working:
https://www.virginmedia.com/help/virgin-tv-lost-or-damaged-tv-remote/download-tv-control-app
SORRY Doesn’t work for TV 360 - just tried.
roy247
  • 1.38K
  • 101
  • 327
Knows their stuff
Message 10 of 16
I've had my 360 since the start of September and not had to change the batteries yet. I haven't used the voice activation much apart from checking to see if it works, to me it's shouldn't be pushed as such a big feature but hey, get the basics right first. Don't know why you guys are having so much problems with the batteries. I saw the 4.28 had this improved battery diagnostic, why is it not available through the settings / diagnostic menus so you can check the battery level I thought that would make sense.
