Paul08
No picture,sound intermittent
Hi,my 360 box was working fine for a day or so,now there is no picture and the sound is intermittent every 2 seconds, tried plugging out and rebooting my virgin media router to no avail,all connections are tight and correctly installed, could i get some help please.
roy247
  • 3.33K
  • 288
  • 777
Wise owl
Re: No picture,sound intermittent
Is your problem with live TV or ondemand and catchup or both, you could also check any recordings you have. If streaming services are OK and it's just live TV have you checked the coax connection to the 360 box as live TV comes down the coax cable. If it's everything have you tried a different HDMI cable and connector on the TV. You can also run the diagnostics test, you will find that in Settings, Network, Diagnostics. If everything else fails try a factory reset of the box, select the option to keep your recordings.
  • 15.86K
  • 2.1K
  • 4.98K
Hi @Paul08
Has the advice given by 360 expert  @roy247  managed to resolve your issues?
Dave
Love, love and love, forever - Pele
