Star10
  • 5
Message 1 of 11
Netfix sound issue
Changed to 360 a few weeks ago, but still having constant sound problems when we go to Netflix. No sound, have to switch off/on the box..and on occasion when it does work, there is no sound when we switch back to tv. What is causing this?
Tags (2)
japitts
  • 12.22K
  • 1.7K
  • 2.63K
Message 2 of 11
Re: Netfix sound issue
Is it only the Netflix app that causes this?
What about other streaming apps - YouTube, iPlayer, Prime, C5 etc?
And OnDemand programmes?
Corey_C
  • 3.98K
  • 220
  • 335
Message 3 of 11
Thanks for your post and for reaching out to the Community Forums, Star10,
Are you still having issues with your Netflix on the TV360? Have you tried the other apps as japitts suggested?   We do also have our online help troubleshooter here: https://www.virginmedia.com/help/services-support/tv
Let us know if you need any further help.
Cheers,
Corey C
Star10
  • 5
Message 4 of 11
I will try those at the weekend and see, thanks
Corey_C
  • 3.98K
  • 220
  • 335
Message 5 of 11
You're welcome, Star10, keep us posted.
Star10
  • 5
Message 6 of 11
It seems to be just Netflix? I've tried a few others and they are ok
Gareth_L
  • 6.94K
  • 424
  • 781
Message 7 of 11
Hi Star10
Can you please try a new HDMI cable ans see if that helps
Gareth_L
Star10
  • 5
Message 8 of 11
The cable was replaced..the new one that came the 360 box
Gareth_L
  • 6.94K
  • 424
  • 781
Message 9 of 11
Thanks for replying Star10
Do you have the old cable still?
Gareth_L
Star10
  • 5
Message 10 of 11
I think so...have a couple of older ones . Why would this matter if the normal tv is working fine?
