This has become absolutely ridiculous, called via 150, explained my issue of not being supplied a power supply with my 360 box, after a bit of delay while they identified what box I had, I was given assurance one would be posted out 1st class and would arrive within 5 days.
Weeks later still nothing , again I have called via 150, this time held for lengthy periods whikst repeatedly trying to explain situation - no power supply. Call centre op says he has escalated the issue to a virtual engineer, and I will receive a call within 4 hours.
'Engineer' has now called, asking to run tests on the equipment to identify the fault, I explain that it is a self explanatory fault (no power supply) and that no tests are going to resolve it. Again, he states they need me to be at home so they can run tests on the service... Ended the call out of sheer fustration at the inept morons.
Please can anyone advise on the power supply voltage, and connection size requjred for a 360 TV box? I clearly need to source my own unit as VM are beyond useless.
