Craig_85
  • 5
LGCX magic Remote and Virgin 360 Box Help
managed to get the 360 box to work with the magic remote, I have one problem.
I cannot hide the 360 box and get it to work, but works with 360 remote when hidden.
I was under the impression 360 box was HDMI-CEC and could be controlled with magic remote when hidden?
any help or advice would be great.
Tags (1)
DJ_Shadow1966
  • 6.65K
  • 1.28K
  • 1.81K
Re: LGCX magic Remote and Virgin 360 Box Help
Hello
It does use CEC but your magic remote is using IR to control the v360 box, the v360 will not work hidden with your magic remote as that remote doesn't use RF, thats why the v360 remote works.
Regards Mike
Craig_85
  • 5
Thanks for that, ordered a magic eye
