on 14-10-2022 17:16
I want to install a Virgin 360 box & 2 mini boxes.
I have Virgin broadband & have Ethernet cables to each location where the boxes are to be installed.(3 in total). The furthest from the hub about 20Mts.
Am I able to pass the TV signal via these Ethernet cables to the boxes & keep the internet connection.
Any suggestions will be appreciated.
Thank you
Answered! Go to Answer
on 14-10-2022 17:20
The TV signal requires a co-ax connection.
All Virgin Media set top boxes require both internet and co-ax connections.
on 14-10-2022 17:20
on 14-10-2022 19:09
It’s coax. Not co-ax.
on 14-10-2022 19:46
… said he/she who doesn’t want to identify themselves.
I’ll stick with co-ax. Coax means something entirely different.
on 29-10-2022 12:32
Is it possible to split the incoming cable 4 ways, without any loss of signal strength, to connect a HUB3, a 360box & 2 mini boxes.
Thank you
on 29-10-2022 13:33
The installer will split the incoming cable to suit your installation requirement and ensure, perhaps with changes at the local cabinet, that your signal is well balanced.
on 29-10-2022 16:26
on 31-10-2022 20:13
Hi @TonyCrowe,
Thanks for your post- I am pleased to see Ernie_C was able to help you 🙂
If you need anything else, let us know.
All the best!
