Hunter12392
  • 5
Does fitting ethernet cable to 360 box disable wifi
Does fitting ethernet cable disable WiFi on 360 box.
japitts
  • 19.28K
  • 2.5K
  • 4.41K
Re: Does fitting ethernet cable to 360 box disable wifi
Indeed it does.
Both V6 & 360 are designed to prefer Ethernet cable connections over wireless ones, and so an Ethernet cable will disbled WiFi.
roy247
  • 2.78K
  • 216
  • 639
Trouble shooter
You only have the choice to select either ethernet or Wi-Fi in network settings. As the box only connects to the hub if you switch from Wi-Fi to ethernet it would effectively turn Wi-Fi off.
