on 03-10-2023 22:42
We having problems with most of channel 5 programs ie keeps stopping and showing problem with this channel then closing the 360 box, when watching a recording from most channel 5 same thing happened
on 04-10-2023 20:38
Hi having trouble with all channels on 5 while watching any channel 5, 5 action, 5 USA they keep on stopping and resetting the set top box comes up with code 2002 any ideas, done the turn off and on again on the set top box
on 06-10-2023 13:25
Hi Steve7555,
Thanks for posting, and sorry to hear you're having some issues with the TV.
Can you confirm if you've rebooted the equipment? Any other channels with issues?
Alex_Rm
on 06-10-2023 14:55
Known issue it seems, I have had similar problems with many of the 5 family of channels.
There is a general post about an issue with getting CS2002 error codes and rebooting at the top of the topics.
on 06-10-2023 14:56
Ummm, look at what one of your team has posted!
on 06-10-2023 18:34
Hi Alex I have rebooted the equipment it is just the 5 channels it happens when watching programs live
Thanks steve
on 06-10-2023 20:03
We are having this problem too. Near Bristol.. It says something like check your cables then it goes on to reboot the 360 box. I dialed 150 on the phone and after the usual "press 1 for" etc it tells you to look on the web. The web says nothing, and now I am on the community forum it seems to have changed from its past very clear menu structure to something that doesn't work very well at all. Virgin, as in the past, make themselves hard to reach when there is a problem. Well.....we only pay the bills after all, so don't really deserve the chance to talk to someone who might actually listen and/or have some explanation!
on 09-10-2023 09:17
Hi @Roseyhue thanks for your post here although we're sorry to hear of the concerns you've raised here.
There aren't any issues on the line at the moment that could be causing this, but unfortunately we can't run checks at the moment as your box is showing offline so could you please let us know when the box is on and we can re-run the checks for you?
Many thanks
on 09-10-2023 12:55
Hi Tom
The 360 box is on now.
But are you saying that you have found a fault in the 360 boxes for all these other people who have the same problem?
on 11-10-2023 13:09
Hi @Roseyhue
Can you share a video showing this please as I've not heard of this issue.
Best wishes.
