What is the channel number and name you EastEnder link is set to - can you post an image from your SAVED folder?
I do find the 360 doesn't seem as good for video quality as the V6 - but don't find a massive difference.
@joebloggs wrote:
I had a bunch of episodes of Eastenders recorded and when deleting one episode I recorded it went to the next episode delete option and deleted an episode I was about to watch.
However going from a recording to BBC iPlayer I noticed a small upgrade in picture quality.
Just a heads up - I don’t have any pixelation or service issues
Having both Sky and Virgin it does seem that the channels are significantly lower in quality than Sky, are they taking DVB-T feeds off channels like Really and Drama? Only channel that looks better is Talking Pictures TV
1.2Gb/55Mb in Area 31
