vikingbeard
  • 28
Message 1 of 9
Audio Description on when not sctive in settings DMAX on demand episodes
Hello
For the past week I have Audio Description when viewing on demand content from DMAX.
Specific details:
Equipment: TV 360 mini box
Channels: DMAX on demand
Content: Fast N' Loud - Series 13 onwards - All episodes
Issue: Audio Description is present on all episodes when not active under settings
Troubleshooting: Checked under settings to confirm Audio Description is switched off, restarted box, issue persists for close to 1 week now.
No other accessroies paired to the box, no changes made to my setup since installation.
  • 10.44K
  • 1.44K
  • 3.08K
Message 2 of 9
Re: Audio Description on when not sctive in settings DMAX on demand episodes
I checked series 13, episodes 1 and 2, and series 15 episodes 5 and 6  via DMAX On Demand and none of them had AD on.
TV360 version 4.31
Since a reboot didn't fix your issue try a factory reset.
To factory reset go to Settings (the cog at the end of the Home menu) > System > Factory Reset.
With the 360 you won't lose your recordings or series links as it's not a complete factory reset, however you will need to sign into apps such as Prime, iPlayer and ITV Hub again.
EDIT Do you have the same issue on the main 360?
Dave
biondani
  • 79
  • 12
Dialled in
Message 3 of 9
Same thing happens to me with Wheeler Dealers on same channel. Doesn't seem to affect any other channel though.
Molly_G
  • 1.15K
  • 53
  • 136
Message 4 of 9
Hey @biondani,
Sorry to hear you're having issues with the audio description at the moment.
Just to confirm - does this occur when you record the programme and watch back too? Or is this only when you watch the channel live?
Molly_G
biondani
  • 79
  • 12
Dialled in
Message 5 of 9
It's only when I select watch from start in the channel guide. It doesn't happen when I watch live.
Molly_G
  • 1.15K
  • 53
  • 136
Message 6 of 9
Hey @biondani,
Thanks for confirming that. Have you tried any diagnostics stated above - rebooting the equipment etc.?
Kind regards,
Molly_G
biondani
  • 79
  • 12
Dialled in
Message 7 of 9
Haven't done a factory reset as it is a new upgrade anyway but I have rebooted and has made no difference.
biondani
  • 79
  • 12
Dialled in
Message 8 of 9
It is the main 360 box I see it on which is an upgraded V6.
Martin_N
  • 7.15K
  • 303
  • 451
Message 9 of 9
Hi biondani,
Thank you for your post.
We would recommend trying all recommend steps.
Once you have done then all please do let us know.
^Martin
