carolbrowne81
Arrows flashing on tv box. Help
I have the 2 arrows flashing on TV box any ideas
japitts
  • 20.72K
  • 2.65K
  • 4.75K
Re: Arrows flashing on tv box. Help
This often means the internet connection (via your homehub) isn't working - can you use OnDemand or any streaming services? If not...
How is your 360 connected to your homehub, is it Ethernet cabled or wireless?
Ernie_C
  • 20.04K
  • 2.22K
  • 5.19K
This means that your TV 360 has lost its internet connection.
Are other devices on your broadband connection working OK?
If so, it may be worth checking the TV 360’s network connection by going to the NETWORK section of the TV 360 settings.
