on 01-01-2024 22:41
I’m looking to have a 3m caux cable extension to be sent out.
can someone please advise how to get this arranged?
thanks
on 01-01-2024 23:17
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 01-01-2024 23:30
The best way to do this would be to call Virgin and choose the option to report a fault, then ignore all the options offered and you should then be placed into a queue to speak to someone.
There should be a £25 non fault call out charge but the engineer can check your signal levels and adjust if needed in the street cabinet.
on 04-01-2024 11:05
Hello paulorock89,
Welcome to our community and thanks for your first post.
I can arrange for the 3m coax to be sent out for you.
We do actually do them in 5m, 10m and 15m if that helps.
What I will do to arrange this is send you a private message.
If you can check the logo top right of your screen that would be great.
Gareth_L
