360 remote paired with Panasonic audio keeps sending a spike to the audio sound when used
brianP74
This spike (quite loud) is driving me, wife and dog up the wall. Have re-paired, put in new batteries next job is to throw it out of the window. Can anyone give any help please?
1 ACCEPTED SOLUTION
Accepted Solutions
ozsat
Superstar
If you mean a high-pitched audio when changing between some channels - it is a known problem with the Panasonic TV which occurs on Sky boxes too.
Or are you having a different issue?
1.2Gb/100Mb in Oxford (area 31) using SH5
6 REPLIES 6
ozsat
Superstar
Natalie_L
Hi brianP74,
Welcome to the Community and thank you for posting.
We are very sorry to hear you are experiencing an audio issue.
Can you please confirm what is happening and if the issue sounds similar to what ozsat has described?
Thank you,
Nat
brianP74
Hi, The issue is very much as Ozsat describes although we never had it on Sky (just changed from them to Virgin), nothing extra added and basically just changed the relevant boxes.
Brian
brianP74
I did reply to Ozsat and thanked him but can't see it on this thread.
Hi @brianP74
It looks like you thanked @ozsat by marking the post as a Helpful Answer 😊
Dave
The do's and don'ts.
It only occurs if your box is set to Dolby 5.1 output - it occurs when the box changes between 2.0 and 5.1 and the Panasonic TV (and a few others) give the feedback type noise.
It also only occurs if your set-top-box HDMI is direct to the tv.
If you are only using the tv for output - use regular PCM 2.0 audio and not 'Follow Content'
Brian
