on 16-09-2022 01:44
on 16-09-2022 12:29
Hi @CrazeUK
When setting up the 360 remote it's generally the first 4 characters after the screen size that need to be entered.
Please try UH62 and if that doesn't work then try 625V
If you need to go via the key testing method then don't just accept the first one that suggests it's paired. There are often 3 or 4 variations that will pair, some more succesfully than the others.
on 20-09-2022 11:45
Hi thanks for that.
I did try using both those codes, as well as the key testing, and there was nothing.
The TV it self is about 4 years old so assuming it's still relevant enough.
Is it possible to use tge universal remote codes?
on 22-09-2022 11:56
Hi there @CrazeUK, welcome to the forum and thanks for your post.
I'm sorry to see that you are having issues with using your 360 remote to control your TV. Just to confirm, have you been able to follow the steps as shown here?
Let us know if you need any further help, we will be happy to help.
Nathan
on 24-09-2022 03:08
Hi thanks for your response.
No joy unfortunately
on 26-09-2022 10:01
Hi @CrazeUK,
Thanks for the update, I'm sorry to hear things still aren't working. Can you please try the following:
- Turn the TV Box on
- Press and hold the TV + 0 button on your remote for 10 seconds
You should then see a notification advising that "Pairing is successful", from there, please head to Settings > Audio & Video > Pair Remote with Device and select Change TV Setup - you'll then be able to select the TV Manufacturer and setup the remote.
From there, please reboot your equipment by switching it off at the back of the TV Box, and then switching it back on after 10-15 seconds. Please let us know how things go.
Cheers,
on 26-09-2022 12:07
Thank you.
Unfortunately no joy. Holding TV + 0 down for 10 seconds does nothing.
on 28-09-2022 12:15
I'm so sorry to hear that this has not helped and thank you for letting us know!
I think it would be best to get a replacement remote out for you, I'll just pop you a PM so we can arrange this.
Keep an eye out for the purple envelope in the top right corner of your screen alerting you to a new message.
Thank you.
on 28-09-2022 13:02
Thank you again for popping back to via the PM and I have ordered the remote for you now.
It should be with you in 3-5 working days. Are you able to let us know how things are looking after the remote arrives?
on 28-09-2022 13:09
Brilliant thank you.
I definitely will follow the steps through again then update.
