Emmet1965
360 box Sound issues with recordings
Hi, I've noticed over the last two days that the sound on the recordings and replays I have been watching are awful, sounding like I'm listening through water. When I jump back to "live" there is no issues. Is there anybody else have encountering this. Would it be a coincidence that an engineer was out on Wednesday doing a line fault?
Tags (1)
  • 6.45K
  • 1.01K
  • 1.59K
Re: 360 box Sound issues with recordings
Hi Emmet1965,
For Sound issues go to Setting > Audio & Video - try setting Dolby Audio to always convert.
You can also try different settings such as follow content or disabled
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
