360 TV remote shortcut to switch between TV Guide filters and planner?
mc09779
Daft question, but when scrolling through the TV Guide, is there a button to switch between to the Day/Genre filters at the top of the screen and the TV Guide planner itself?
The only way I can find for getting to the filters is scrolling all the way to the top of the planner but there must be a shortcut. I've checked the helpful diagram on the support pages but there is nothing there.
1 ACCEPTED SOLUTION
Accepted Solutions
1701-e
Superfast
Just press the home button and you'll be at the top of the guide.
4 REPLIES 4
1701-e
Superfast
Hi @mc09779
When searching on the EPG you can also press the Home button, then press Right on the remote and it takes you to the navigation section of the guide with All Channels highlighted. If you then click OK on All Channels it brings up a dropdown category list:-  Documentaries, Entertainment, International, Kids etc so you can go straight to that section.
Dave
The do's and don'ts.
mc09779
Thanks to both of you. Home button is the one!
Tom_W1
Hi @mc09779 thanks for your post here in the Community, although sorry to hear of your confusion here.
We're glad to see that thanks to @newapollo and @1701-e you have been able to get things resolved.
If you do need any further help, please don't hesitate to let us know!
Many thanks
Tom_W
