on 04-11-2022 10:25
Got a new TV, JVC LT-43CA890, Remote pairs when I go through steps below, but it wont control TV volume or power
Tried factory resetting the remote and then pairing it again
on 04-11-2022 12:00
If you have changed your TV then try this,
Settings > Audio & Video > Pair Remote With Device then select the option for Change TV Setup from there you can manually choose your TV manufacturer and setup the remote control to pair with the TV.
on 04-11-2022 12:06
Hi, thanks for reply. I tried this and still no luck
on 04-11-2022 12:28
Have you tried removing the batteries and then resetting, that has worked for some people.
on 04-11-2022 12:42
Hi Yes, tried that also
on 04-11-2022 15:02
Have you tries new batteries? This has worked for a fair number of people.
Also try the key testing method, Audio & Video > Pair remote with devices > TV devices, but don't just accept the first one that appears to work. Try a few more as (like the older V6 and Tivo boxes) there are often 3 or 4 that will work, some more fully than others.
on 07-11-2022 08:58
Hi alan1116,
Welcome to the Community and thanks for posting.
I am very sorry to hear you are experiencing issues syncing your remote to your new TV, we will do all we can to help.
Can you please confirm if you have tried new batteries and if this helped?
If not, support is available here.
Let us know if we can assist further 🙂
on 07-11-2022 12:13
Hi Natalie, yes i have tried
1. New batteries
2. Reset and reprogram sequence (Pressing and holding the TV and Rewind button for 10 seconds & ressing and holding the TV and Rewind button for 10 seconds)
3. Pair remote with devices CHOOSING JVC > TV devices – Tried multiple times – went through all options, still wont control volume
4. Pair remote with devices > TV devices
Appreciate any other steps you could advise
on 07-11-2022 12:25
Just writing to suggest something worth looking at, rather than assuming I know the answer...
Does the TV 360 remote try to control the TV through infra-red, or via the HDMI cables (CEC etc.)? If the latter, maybe your TV needs to have HDMI-CEC enabled before it'll accept the control signals from the TV 360? Looks like you want page 50 of the instruction manual.
on 07-11-2022 12:35
Thanks, ill try that and post back later today. With CEC enabled does it need to be connected to HDMI ARC PORT
