spangley
  • 76
360 Box offline or not connecting
Hello
I am trying to watch some recordings that are on my 360 box in the living room on my 360 box in my bedroom
For the past two days I keep getting " the virgin TV box is offline or not connecting.  Turn it on to watch your recordings " the box in the living room is definitely on
They are all hooked up to the same network
Any help would be much appreciated
roy247
  • 2.76K
  • 214
  • 633
Trouble shooter
Re: 360 Box offline or not connecting
Don't know what you have already tried, you could try turning both boxes off with the switch on the back of the box and if that doesn't work you could try a factory reset, you won't lose your recordings if you select option 1 to keep your recordings.
Gareth_L
  • 10.77K
  • 600
  • 1.19K
Hi spangley
Thanks for your post
Can I please ask how things are now
Are you able to view recordings now
Gareth_L
