Message 1 of 5
voicemail pin
I have a new pay monthly sim card and activated voicemail within the account settings
when dialing voicemail it is requesting a pin number which I do not have, is there a default one?
  • 4.78K
  • 694
  • 1.28K
Message 2 of 5
Re: voicemail pin
Mine was 1234
  • 5.58K
  • 775
  • 1.58K
Hero
Message 3 of 5
Re: voicemail pin
If dialing within the UK, it really should not be asking for a PIN code - usually only need it when roaming abroad or dialing from another phone/SIM.
Not heard of a default PIN for voicemail, I believe 1234 is the PIN used when asked for code when Provisioning settings are installing.
Think you will need to get in contact and have a temporary PIN set-up to get access, then you can change to your desired PIN.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only. Customer since 1993.
Message 4 of 5
Re: voicemail pin
thank you,, the fact the the phone is now in Spain and I did not set he voicemail before sending it over,  will probably explain it. Is there a contact email that will get this sorted? or will i have to hang on the phone for hours.
once again thank you for you help
  • 5.58K
  • 775
  • 1.58K
Hero
Message 5 of 5
Re: voicemail pin
It will be waiting on 789, try using the Text service (07533016422) or hanging on here for a member of staff to offer help - which may take a couple of days 🥴
