voicemail PIN
I have recently switched to Virgin and am currently abroad and unable to access my Voicemails due to the fact I didnt setup my Voicmail PIN before leaving the UK. Searching the forums on this subject it appears that I can request a temporary PIN to be setup by a helpful moderator, is this still the case and how do I request this ? Failing that does anyone know what the tarriff is for calling 789 when abroad as there appears to be a charge.
  • 3.62K
  • 224
  • 458
Re: voicemail PIN
Hello 5morgasbord
I will need to send you a private message to get this sorted
Before I fo I just need to be certain this is for a landline and not a mobile
Gareth_L
Re: voicemail PIN
Hi Gareth, thanks for replying. No this is not a landline but my mobile, hence the using abroad.
