albsat
simcard
this is my very first letter in about 14 years
i have recieved a text message from virgin media,
hi, its virgin media we recently asked you for your postcode,its really important that you send it to us so we can post you a new sim card and aviod any disruption to your. service..  we only use this number to confirm address details and it will not process any other info so please reply only with your postcode.
thanks
i think this is rubbish myself they should know my post code.
regards
enlli
  • 7.04K
  • 1.11K
  • 1.98K
Re: simcard
They need it to check that the address they have for you is the right one.  I hope you let them know because without it you may end up being cut off when your present SIM expires.
albsat
Re: simcard
thanks for your reply ,i will get in touch
