OFCOM_next
reset voicemail PIN
Can someone reset my voicemail PIN number? I keep getting alerts telling me that I have a message waiting. Normally I just dial VM and it lets me straight in. However virgin mobile phone service has been down since Friday so I'm having to use my home phone and I am then prompted for the PIN which I have no idea about
Tags (1)
Megan_L
  • 2.1K
  • 129
  • 210
Re: reset voicemail PIN
Hi OFCOM_next,
Thanks for using the forums to get this issue with your mobile voicemail services looked into, I am sorry if this has been causing some frustration. I would be more than happy to look into this for you.
I can reset your voicemail pin for you on my side, we will need to go into a PM in order to pass security 🙂
I'll send this to you now.
Megan_L
