on 05-01-2022 16:16
Please would you advise me how to order a replacement sim card for my existing card which is the old type that will not fit into the newer smartphone. Thank you
on 05-01-2022 16:42
Hi @Portmandan1
Thanks for posting on our community forum!
I'm going to drop you a private message to investigate further, please keep an eye on your inbox.
