problem receiving calls abroad
colshaws
I have just arrived in Ireland, I can make outgoing calls but when my phone rings and I answer I am not connected to the caller in the uk although the call timer shows I am connected. I have data roaming  turned on and I have used thisphone in Ireland before with no problems.
136 REPLIES 136
Gareth_L
Hi colshaws
Have you powered the phone down then back on and tried a manual Network search
Are you able to send and receive Text Messages okay?
Gareth_L
yes , powered down and back on, I have tried on different networks but all the same,I can dial out and talk no problem but if I get an incoming call it rings but when I answer it I can not talk to or hear the caller,text messages are fine.
Thanks for coming back to us @colshaws. What is the signal level that you have, when getting these calls?
Do you have any call barring set onto your account?
When was the last time that you got a new sim card?
Regards,
Steven_L
Signal is good, no problem calling out, same SIM card for years but had no problem when I was here in Ireland 2 months ago
Thanks for your response @colshaws.
I can take a further look into this from here but would need to confirm a few details via a private message.
I will drop the message over in a moment, please look out and we can get started.
Regards,
Steven_L
The message should be with you now @colshaws.
Steven_L
I have replied via PM
Thanks for confirming your details via private message @colshaws.
I have reset the settings on both handsets, please can you turn off off both handsets and reboot them to see if this resolves anything.
Regards,
Steven_L
