soldierboy
mobile phone start problem
My mobile has a problem when I try to use it. I now have to select and double tap each letter when signing in. Then I have to touch each app and double-tap to enter the app. It was working fine. \ I must have inadvertantly touched something when I put it away. I get verbal information each time I touch a button. It just informs me of what I have just done. Must be some sort of easy fix  but I do not know, Any assistance would be good, I am unable to go to phone shops are they are all locked down
enlli
  • 8.02K
  • 1.25K
  • 2.29K
Re: mobile phone start problem
If you are getting verbal notifications check that you have not switched Accessibility Options on by mistake. Sound like the one for Visual Impairment
soldierboy
Brilliant thank you so very much. All working good now
