@enlli wrote:
Well known problem.
Go to: Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming" -> tap "Select Mode"
Tap manual -> then choose National.
Make sure your numbers are set to the correct format. If not change region to anything other than UK (Settings -> General -> Language and Region -> Region) and then change back to UK region.
Thanks, so effectively setting the iPhone to manual roaming, correct? Sad thats its so well known as a problem but not resolved on Virgins’ end.
