Lui
Just joined
iPhone XR unlocked but won't work
I have an iPhone XR purchased at a Virgin Media shop.
Everyone (the shop, and other tech shops in Dublin) says it's unlocked.
So, when I traveled and my corporate phone had better coverage I tried switching my sim card to my "unlocked iPhone" to no avail, the iphone shows 3G but no data.
I tried different irish SIM Cards on my iphone and nothing, however I tried them on my non-virgin unlocked phone and they all worked.
Additionally, I tried my corporate SIM on a my sister in law's slovak unlocked iphone and it works, so that's ruled out as the cause and leaves only my Virgin Media iPhone.
I'm currently in a remote location and would really like to use my phone, plus, in 2 months I'll be leaving Ireland and having an unusable iPhone is kind of a problem.
Thanks in advance for the help!
BR,
Lui
DawsonFaris
Re: iPhone XR unlocked but won't work
reset the device or else return it
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.9K
Hello
With regards to your mobile contract is it UK or IE, if it IE I am afraid that this forum cannot help you as this forum is for UK customers, you can contact Virginmedia IE at https://www.virginmedia.ie/contact/
Regards Mike
