  • 25
  • 7
Message 41 of 110
Re: iPhone Dial Assist Problems
I’ll give it a go tomorrow and report back soon.👍
Message 42 of 110
Did a factory reset about a month ago with my iPhone SE as advised by Apple......worked for a bit, then went wrong again after a week! I reckon it’s futile! ☹️
  • 9
Message 43 of 110
Just wanted to quickly add my name to the people who are finding this a problem. I just had to spend half an hour searching the internet to find out why I couldn't send a text message to my boss that he was expecting. This is not just frustrating and annoying, but also has implications for my future employment so I'd really be very interested in getting a solution to this problem.
  • 15
Message 44 of 110
I experimented with the reboot suggestion and found that it was successful 3 out of 3 when the Contacts App was closed and failed to resolve the format when Contacts remained open again 3 out of 3. Granted a small sample.
I also tried a "Reset Settings" which did not resolve the phone number format as it returned again within a day..
The final option is the full factory reset and then restore unless anyone has a less time consuming suggestion.
  • 9
Message 45 of 110
Just done a full reset and restore on my iPhone and the problems returned within a few hours. I have tried everything on this problem now. No help from virgin About this so will be requesting my PAC and try another provider to see if this will fix the issue as it seems to be a virgin network fault.
  • 15
Message 46 of 110
Ashie2112
When you did the factory reset did you do a full install from scratch or restore your device from a backup?
  • 9
Message 47 of 110
I reset to factory and then installed all my apps and settings from a backup.
  • 9
Message 48 of 110
derekterry
i did a full factory reset and then restored my iPhone from the cloud backup. Can still report that my phone hasn’t had any more phone format problems (fingers crossed).
Message 49 of 110
I came across this thread when trying to troubleshoot this issue for a friend. On his third visit to an Apple Store the person attending to him shouted to a colleague a description of the issue. The immediate response was "is he with Virgin?" My friend then changed networks. That was over a month ago and the problem has not appeared again.
  • 605
  • 8
  • 21
Fibre optic
Message 50 of 110
Popping in to add my name to the list.
IPhone xs and Virgin Mobile SIM.
Intermittent issue. Very annoying..
