iPhone 8 silent switch
  • Hi, anyone had any issues with the silent switch on aniPhone 8 staying in the down position. Every time I move out to the off position it springs back down Silent.
  • 101
  • 11
  • 10
Up to speed
Re: iPhone 8 silent switch
Yes I have this from time to time- take a small pin or needle and GENTLY pick away any dust that may be in the switch, and then try again
bits of trouser fluff can accumulate and block the switch from working properly- same with the charging port
Thanks I’ll give it a try
