adamwells95
iPhone 12 Pro Max - Number format changing to belgium
Every 1 - 4 weeks my number format on all of my numbers that do not begin with +44 change to a Belgium format.
For instance:
UK: 07708 123 123
Belgium: 07 708 12 31 23
So any contacts I call it tries to call the Belgium equivalent number.
I have looked online and this has been a recurring issue on Virgin sims for years. I do not want to change any settings, roaming, or any of these other temporary fixes as it keeps coming back.
I never had these issues on O2. It has been immediate since porting to Virgin.
enlli
  • 7.41K
  • 1.17K
  • 2.09K
Re: iPhone 12 Pro Max - Number format changing to belgium
Usually the fix I put out cures it. However, if you don't want to change any settings then you are stuck as Virgin SIM cards are actually Belgian and iPhones occasionally think they are in Belgium. There is no way to change that.
  • 6.51K
  • 1.02K
  • 1.61K
It's a simple settings change that allows the iphone to change the country to UK and doesn't affect anything else.
Go to: Settings -> mobile data -> SIM Applications (near bottom) -> tap "Roaming"  -> tap "Select Mode"
Tap manual -> then choose National.
Mmake sure your numbers are set to the correct format. If not change region to anything other than UK (Settings -> General -> Language and Region -> Region) and then change back to UK region.
Dave
Have I helped? Click to mark as a Helpful Answer or use Kudos to say thanks
